Meguinness
- Oct 24, 2020
- 1
Hi guys, I'm new to this forum and anything related to solar . Im building a power box using 18650 cells , I made 3x 3s15p packs 30A each with bms and connected in parallel to give me 12v output. As I want to be able to recharge the batteries using a power brick and my 120w solar panel kit I purchased and connected a automatic stepup/Stepdown buck converter so when I use the 19v 5a power brick the buck will step down the charging voltage to 12.6v and I assume that when connecting the solar panel kit the buck will automatically stepup or down depending on the panel voltage maintaining the 12.6v output. What current should I use to charge the packs in parallel? The buck as CV and CC that can be regulated. , Would 12.6v at 2A be ok ?
Thanks
Thanks
