Do I need to buy more stuff?
Skooliemom
Ok so got some questions.
I have 4-250w panels see photo. Planned to be wired in series and parallel.
renogy 30 amp charge controller to the batteries.
2 - 200 amp hour AGMs Renogy. (Series?)
fuse150 amp (not sure size???)
then that will run to an inverter (MSW) 1,000w
A fuse block I use A LOT OF 12v (usb) stuff the inverter is just for the TV.
Also got this Alitove DC 12v 20a 240w Power Supply Transformer Switch.
I do carry a 2000w generator
Assuming 24V battery/inverter.
1000W/24V = 41.7A - your 30A controller (assuming MPPT) won't capture all your solar. You need 40A.
MSW inverters are generally more inefficient than PSW. If all you're running is a TV, then I would consider getting the smallest PSW inverter possible. Inverters themselves consume power. Bigger inverters pull more power just by being on even when no loads are applied. Here's a 500W:
Not sure what the purpose is for the 12V/20A power supply.
Not entirely sure what you're looking for without knowing your goals.
One thing that stands out is 1000w of solar and a 30a PWM charge controller.
And assuming 12.8v system (or missing 24v to 12v converter):
1000w / 12.8v = 78a of charging power
Which is nearly 1/3 as bug as it could/should be.
Schoolies (schoolers?) tend to want to just build something and live with what they got rather than plan for needs. (Its early, and i am on my first cup of coffee and apparently judgey today! )
Power supply is for?
I ordered a 40 amp mppt CC today. The inverter won’t be used much so not really worried about it. 12v powers everything lights, refrigerator, phones, tablets, security system, WiFi router, a mixer(yes,12v)
I have been in my bus for almost 2 years. I only had 1-250w solar panel and the 400amp hours in batteries it was not getting full. So I needed more panels. I got a heck of a deal. So I got 4. I have added a picture of the charge controller for you it says 12/24V
no converter but can get one do you have a recommendation?
goals just to make sure my 12v items are powered all the time I honestly don’t need an inverter but have one just because.
Probably a good thing. Make sure you configure your array to falling the MPPT range of your MPPT SCC.
This "may" mean putting panels in 2S2P arrangement but that mostly depends on the panel Voc (found it: 37v) and SCC input requirements.
If you share your SCC input info we can help you set it up to operate most efficiently.
This is what I have now 30 but I ordered the 40. I planned on running the panels in 2S&2P setup. Could you help with the correct connectors. I know what it should be but when I look I get confused lol
Renogy Rover 40 Amp 12V/24V DC Input MPPT Solar Charge Controller Auto Parameter Adjustable LCD Display Solar Panel Regulator fit for Gel Sealed Flooded and Lithium Battery https://www.amazon.com/dp/B01MSYGZG...abc_H6626GCD5C1D1YMVX6DZ?_encoding=UTF8&psc=1
Nothing is done to them yet. I have 2 of them.
Ok you lost me. I have 1 set of MC4 wire with connectors. In photo below I order 1 set of the Y connectors you listed.
Ok but you are buying a 40A SCC which at 12V x 40A is only 480watts panels.
but you have 1000watts panels that will require an 80A SCC. 80A x 12V is 960 watts.
Charge rate of your AGM battery has to be considered too.
Do I need to do a 24v system?
Most of her loads are 12V, so batteries in series for 24V isn't good.
An additional charge controller would let all 1000W (80A) charge the batteries.
Batteries are 200 Ah, in parallel would be 400 Ah, 80A is 0.2C which may be OK. Have a manual for your battery to double-check?
If the panels can be tilted, put one series string of 2 panels facing one way (morning sun), the other string of 2 panels facing afternoon sun.
That will reduce peak current and increase hours of power production. Still over-paneled, but not as much.
Reactions: Dzl
No, it was just a way to fit your existing equipment. (same charge controller handles twice as much power.)
But 24V is only useful if you have a 24V load, typically an inverter.
However, it is incompatible with 12V loads.
