roadrunner
- Mar 12, 2021
- 158
ok,lets hope i can explain this right,cant find an answer yet,
I want a grid tie inverter to try and lower electric bill,cant get caught if it runs backwards.
I was thinking of a 12 volt bank,and a 12 volt inverter.,
My panels would be 2x240 watt,open c volt, 37.2 volts, amps-pmax-7.8
then have a 30 amp charge controller, 60 cell panels
so, it would go panels, to charge controller,to batteries,then to inverter then to mains.
Here is my thought,if i could get it just to lower my swamp cooler use during the day by 20 bucks a month,
my swamp cooler runs at 220 watts on low, double that on high,most of the time we run on low,
so,if i can put out enopugh to cover the swamp cooler running, without the meter going backwards to alert the utility co, i think it is feasable,people used to do this with a suicide cord plugged into a wall socket until the util co decided toput a stop to this with smart meters.
since i am using a charge controller, does the panel voltage matter compared to the inverter since the bank is inbetween the panels and inverter
i am also thinking of making this for an emergency grid down but i will need an off grid inverter
