EDECOA Hybrid Inverter 48V 3000W any good
bugsb
rothwell
want to upgrade a bit at some point and if these are any good it would be perfect for my needs but will it at least hold at 2500w out put befor shutting down
Seagal the matchmaker here ;).... IIRC @SamG340 - also in the UK - has one of that brand. Maybe he has some direct experience?
I would assume a 3000W inverter can run at that load continually.
Yes I have the 5500w 48v , it is fantastic for the money
I did order the 3000w / 24v , it arrived but with issues and errors , Edecoa customer service was good and gave me a full refund on return, no troubles .
I'm sure it was just a bad unit and others will be fine , I haven't bought the replacement yet but I feel confident buying from Edecoa
SamG340
About Edecoa
Any fan noise ?
What's the standing consumption of the inverter?
For example Growatt 5kw has standing consumption 70watts,,, just to have open the inverter when solis and Victron have less than 5watts
SamG340
About Edecoa
Any fan noise ?
Fan noise surprisingly quiet even under load . I'm happy to be in the room with it running
54ws according to my victron shunt , power saving standby mode OFF
Hope that's helps!
victron shunt, that's clever , where did you connect it ?
Does the inverter Edecoa have any app or web interface ?
Is it compatible with Seplos or JK BMS ? what's your setup ?
Any pictures
Thank you
Any pictures
Thank you
Victron shunt was just about the most expensive piece of equipment in my step up lmao (bmv-712)
Shunt sits between the negative battery busbar (block) and the rest of the system, monitoring amps in Vs amps out
Not aware of any communication available on the Edecoa , , I don't know if you can given hook it up to a PC , not looked . Also not sure on BMS compatibility (but I'd assume not ! )
My off grid system, 48v, 3.4kw of solar (most east facing, some south) , TriStar PWM 60a , 15kwh of AGM batteries (ex UPS)& the edicona 5.5kwh all in one inverter
You'll have to forgive my redneck wiring ..!
My edecona is sat in the wrong place right now, needs moving away from the fuse box ,.it's warming up one of the cables by it's vent
Thank you for your pictures and the answers, you helped me a lot.
I don't think I will go for it as it is not suporting comunication with BMS
The price is amazing but only for small projects like.
just looking at one the ( still looking)
EDECOA 4200VA Solar Hybrid Inverter 55-450VDC​
i have a iconica 2000w at the moment 2000w being the joke it cuts out at 1000w (approx), so i was looking to upgrade i only have max 1.400w solar power as thats the max the other thing can take , but not sure if i am ok with the min 55v input the edeco needs
panels are
LONGi Solar Hi-MO 5m 400WP Full Black PV Module LR5-54HIB-400M​
noct
vmp/v 29v
voc/v 34v
stc
vmp/v 31v
voc/v 37v
still keep coming back to the unit above as it gives me a 50% buffer for future poss upgrades , have to find the cash to upgrade to a larger batt pack first , but at the same time keep an eye out for any deals on the unit and be able to grab a bargain
an offer i could not refuse came up for a eco-wothy 3000w hybrid inverter , its output already leaves the more exspensive iconica inverter behind, and as other thread am testing some power safe batteries for my setup
Hi Help needed ( first post )
i need a manual for a Edecoa em-302a.
i have tried downloading it from there website but cant find it.
it did come with a user manual but its too small for me to read.
i cant seem to get the unit to connect via the usb cable it came with and its asking for a password.thanks for any advice
not sure what model number mine is but will check , will also ask the seller i bought mine from if they have a link for a bible ,
Welcome! Sometimes the simplest solutions are the best... ;)
shopping
