neal64ss
Bought the EG4 12k hybrid mini split kit with the Boviet panels from solar soverign. Satisfied with the purchase. Ive installed 2 other mini splits, this is my first solar project.
![20240619_143242.jpg 20240619_143242.jpg](https://diysolarforum.com/data/attachments/226/226213-486a72a5797eae6ef90c33caa7e345d4.jpg)
I did some testing laying panels on the ground and it runs fine (at least in June) on only 2 panels. Two of the Boviet 450w bifacials would output up to about 700w before the AC assist would start to kick in. Most ive seen the mini split draw was just over 1000w total. The unit works seamlessly exactly as advertised. The solar panels in this kit are large and heavy and difficult to move around without a second helper.
![20240621_201658.jpg 20240621_201658.jpg](https://diysolarforum.com/data/attachments/226/226214-5e5ab76c14a0d26648919b535957f916.jpg)
After I get everything working and installed I go to set up schedules to get the most work out of the unit when the sun is up and then less at night. To my surprise, the aircon app, which is good for monitoring energy usage, can only schedule the unit to turn on or off. Thats it. I expected to be able to create a schedule and turn on heat, cool, or dry at certain times at a preset temperature using the app. Nope. Its either on or off. I emailed EG4 and asked and was told thats correct, you can program it to turn on or off.
![20240621_201756.jpg 20240621_201756.jpg](https://diysolarforum.com/data/attachments/226/226215-f33bac8013e598202a12de4b0f2ce318.jpg)
![20240629_161439.jpg 20240629_161439.jpg](https://diysolarforum.com/data/attachments/226/226216-b280434b3494bf12cef805d4806fe8cc.jpg)
![df0c8baa-68c0-471f-a460-0a694511a064.jpg df0c8baa-68c0-471f-a460-0a694511a064.jpg](https://diysolarforum.com/data/attachments/226/226217-d326673aaf76751f238f15846cedb8a4.jpg)
Does anyone on the forum know of a solution to this issue? I guess its not the end of the world, but it sure is inconvienent and seems like a bad oversight to leave the ability to schedule out of the app.
