Was it somebody besides SignatureSolar and CurrentConnected? I'm curious who else is selling EG4 batteries.I just got an email from the company I purchased for saying that the UL listed ones are now delayed till mid-late Oct. Anyone else get a message from their retailer like this?
Did you receive it yet? I'm researching online resellers. It's hard to find one that doesn't have a lot of complaints. They appear to be new. Their domain name was registered on June 22nd. Also, the address they list is a registered agent's address, so no telling where they are. I'm assuming they.I purchased mine from renewablehomesolutions.com
There is a new update that starts the heater 32f or lower and the heaters cut off at 35f and if the batteries are 10% SOC or lowerI hate to ask, but I my searches were unsuccessful .... I saw a thread where someone was talking about the Powerpro only heating the cells while charging... anyone know where I can find the thread?
great, thanks for the update on the update ;-)There is a new update that starts the heater 32f or lower and the heaters cut off at 35f and if the batteries are 10% SOC or lower
You can also stack the rack batteries to the ceiling. You can't really with these. So space efficiency is debatable. You can go wide/horizontal, but that's more space.Ok so not so different than the subject battery except these being built more water resistant, are more space efficient, can take more watts, and appear to be easier to hook up.
Is discharge same on the Trophies?
Server rack batteries are certainly easier to move around if needed.
I take it this requires a firmware update via the rj to USB cable?There is a new update that starts the heater 32f or lower and the heaters cut off at 35f and if the batteries are 10% SOC or lower
What about in combination with the eg4 6000xp. I have no need for the large expensive invertergood question. we are focused on 18kpv. it would be interesting to see if cooperation from our good friends at the 15k company
Hopefully we can get that 9540 with the 6000xp as well, we are off grid and don't need the expensive 18kThats news to me and I’m paying them. Would be great but nobody has dc yet and id have to verify
In all for this & recently bought 1 PowerPro & plan on buying 2 more.There is a new update that starts the heater 32f or lower and the heaters cut off at 35f and if the batteries are 10% SOC or lower
It's really not a big deal, driveline not a drama. The batteries have no problem discharging below 32⁰F... but the BMS will not allow them to charge. I honestly think between the insulation, fridge/ freezer & the inverter that the heater rarely comes on. It's mainly just a backup.What's strange to me is a lot of these battery heater units turn on just above freezing like 35-40F. Where they shouldnt be given full charging current. Seems like ideally you'd keep them at 70F or something, then there's no drama for them to receive the full output of your panels in the morning
I don't have a pic now, I will upload some tonight. I dont' have the 18kpv, but I do have 5 powerpro's connected to dual Sol-ark 12k's. I would imagine that all the way from the busbars to the batteries would be the same.Can someone please show a display of how you would connect 5 powerpro wallmounts with 18kpv including external busbars?
.I don't have a pic now, I will upload some tonight. I dont' have the 18kpv, but I do have 5 powerpro's connected to dual Sol-ark 12k's. I would imagine that all the way from the busbars to the batteries would be the same.
I mounted them to my external wall. Then I went through the back of each of the attached conduit boxes and through the garage wall through 2.5" pvc conduit. From the wall I went down into the top of a 10" wireway that holds all of my wiring.
Inside the wireway I used these bus bars (they come as a kit of 2 black/red) and spaced them about 2 feet apart:
600A 12 Stud Busbars | Red & Black Kit
Manage high-current electrical connections efficiently with the 600A 12 Stud Busbars in a Red & Black Kit, ensuring organized and reliable power distribution in your electrical setup.signaturesolar.com
I then used new 2/0 flexible battery cable as conductors as the stock ones are not long enough. One side I attached the specific ends that the powerpro batteries use as a connector and I had to put crimped ring connectors on the opposite ends of the wire.
I made equal length runs from each of the batteries through the conduit and connected to these bus bars. The conductors from the batteries that are the furthest away will have nice clean runs of wire while those batteries that are closer to the bus bar will have extra lengths of wire that you have to deal with in the wireway.
For each of the positive conductors I have a class T fuse between the bus bar and each of the batteries. I took each full length of red conductor and cut it into a short length with ring connectors (bus bar to fuse) and a longer length of red conductor with a ring connector on one end and the powerpro connector on the other (fuse to battery terminal).
I also have another fortress evault 18.5 connected to the bus bar as well. All the powerpros charge/discharge at the same rate with the fortress at a slightly different rate, but not enough to be concerned with. I attribute this to a different battery composition.
I do not use a battery BMS. I finally got all the settings lined out on my dual inverters and the system works great!
Yes, but note this uses the RS232 firmware update cable not the RS485 firmware update cable. You’ll need one of each to do them all.I take it this requires a firmware update via the rj to USB cable?
