I would say more info is needed.
What is generating those load?
Inductive or resistive loads?
Use of electric based appliances? Dryer, water heater, garage "toys"??
Peak average 15 minute loads do not tell you how long the load is running.
I have the Emporia Vue as well. The 17.6 kwh peak load by itself is not enough info.
For example, what is your daily house load?
You can be drawing 16kw every single hour and it peaks at 17.6kw.
You could be drawing 1kw every single hour and it peaks at 17.6kw
I don't even know how emporia calculates the 17.6 kwh. Not trying to be rude, it just got me thinking. My peak 15min load for the month is 2.90kwh and I average 12kwh per day.
Using my 2.90 kwh per 15 minute, it could be
2.9 x 4 = 11.6kw running at 25% of the time
2.9 / 4 = 0.72kw (this looks wrong already)
Some other way to calculate
Now since this is my house and I know we have used two small electric deep dryers (1.5 kw each with some cycling from thermostat) at one time for dinner, I am more inclined to say that it is X 4 so it would be 2.9 x 4 = 11.6 kwh for an extrapolated hour load draw.
That's my guess on what the app is trying to do at 6am in the morning before my coffee boost.
