cowduck
I have a question about the EG4 18kPV specs: https://eg4electronics.com/backend/wp-content/uploads/2023/04/EG4-18KPV-12LV-Spec-Sheet-1.2.1-1.pdf
I will be getting this setup + 1 powerpro battery soon. Grid tied and setup with 200AMP load center.
I understand when the grid is down I am limited to 50A or 12,000 Watts output. However, when the grid is up am I still only limited to 50A?
The specs say "Max. Continuous Output Current" 50A. Then AC Bypass (Grid) 200A. Does this mean I am limited to 50A even when the grid is up? Or am I reading this wrong, and I get the full 200 amp output when grid is up?
