Now that I look at it more closely, that's an Isc limit, so the unit can't even pull 12A from the array - closer to 10A
That means your Vmp needs to be close to 300V to ensure you have enough power to run the unit at full load.
In looking at these specifications, I'm deeply disappointed with this unit's PV capability. It's pretty pathetic. For a temperature margin, you need to have Voc down around 315V. That puts your Vmp down around 252Vmp. With about 10A (maybe 11A) of actual draw from the array, that puts you at about 2600W max theoretical array. Unfortunately with hot temperature effects on PV voltage, you're going to be closer to 227Vmp. At that level, if you're not pumping 10-11A (1000W/m^2), you can't supply the needed power to the unit to run at full blast.
I was seriously considering this unit with the idea that I could over-panel it for extended high load running from PV from like 10a-2p. Now that I see the PV capabilities are so marginal, I can't consider the two ton unit AT ALL. It's PV capabilities are at the minimum.
This is a crap design. VERY disappointing. Going to have to look to other options.
OP, sorry you got suckered.
