Trkarl
I purchased 3 eg4 48v 100 ah waterproof batteries from Signature Solar in March of 2022. They have been in service since then daily. At first they were not balanced at all. Slowly over the months they balanced out okay. I also run them parallel with a diy 304 ah battery with a jk bms that works flawlessly. Daily I monitor
everything especially when the batteries are absorbing to check the balancing and voltage of all my cells. Everything has run perfect for 2 years.
I was out of town for 10 days so the system charged and then floated for several hours every day. Today when I checked all my batteries while absorbing each of my eg4 batteries was extremely out of balance. Surprisingly each one had 2 cells at 3.67v and several cells at 3.35v. They were not this far out of balance when I first got them. How can they go this far out of balance in 10 days especially when for several days in a row they were able to absorb and balance?
My settings are bulk to 55.2v, absorb @ 55.2v for 1 hour, float @ 54v . My charge controllers are Victron Smart Solar 150/70 and 150/60. I checked the logs and each day they did what they have always done.
My concern is the cells getting over 3.65v . The spec sheet says over voltage protection from the bms is set at 3.9v which seems too high. Any ideas how this could happen? Maybe I should just buy 3 jk bmses and replace them before the cells are ruined.
