EG4 6000ex Line Charge on Low Battery
azweb76
USA
Hi all. I have the EG4 6000ex connected with AC input. I only want AC input used if the battery is below a certain percentage. Do you know if this is possible without Solar Assistant?
You can do that with setting 20 as a voltage......don't know about Solar Assistant
Yes, if you’re on the current firmware then you can use setting 20 and 21 to switchover to grid and battery at a specified battery percentage SOC.
Ah. Waiting for the usb cable to install firmware. Is there an update to the manual based on the latest firmware?
I think there is a manual in the firmware download. I assume it’s the updated version consistent with latest firmware.
