David Martin
Hi guys, sorry if this is a newbie question, i did search. This weekend I commisioned my off grid system (1 Eg4 6000ex, 1 eg4 life power batt, and 4k watts of panels). The unit seems to work great for small 1000 watt loads, but if I try to run my 1800 watt 120v chop saw or 2000 watt 230v well pump it triggers the 07 "overload" fault code. Any ideas why? I'm suspicious I may have my neutral ground bond setup incorrect. I have neutral and ground isolated/seperated at my breaker box and "enabled" at the inverter. Thank you for any help.
