Check the following settings to enable or disable the low amp grid assist battery charging. You must use the phone app verify the Battery ECO setting.
The following two settings must be properly set:
- Battery Eco = Enabled
- On Grid EOD = higher voltage/SOC% than current battery voltage/SOC
If the On Grid EOD voltage/SOC is below the current battery voltage/SOC, the inverter will add that small amount of AC charging (even when AC charging is disabled). If the setting is higher than current battery voltage it will not AC charge. If Battery ECO is disabled, On Grid EOD will have no effect on AC charging.
