jfcruz
Hello all, I was directed to this forum by Signature Solar to see if anyone could help me in resolving my problem by fixing the 6500 inverter's display to come back on. Problem summary: I initially contacted SS because I wanted to know what battery setting I should select since I had eg4 batteries and battleborn. And why some of my settings I chose to change/ use were not being saved within the unit. The tech had me go through the last settings to see if I had the latest firmware. I did not for one of them, I needed to update the U1 firmware he said. This was a whole work out, such as I had to update the firmware via a bridge connection using comm serial port. This is not as easy as it use to be, since Windows 8 because Microsoft doesn't use these kinds of ports they use USB so now I needed an adapter, then a driver to remove the windows conflict before it let me use the adapter, on and on. Then download the firmware and the Remote Panel reflash tool, and save it. By time all was done, It took me a whole day, 7-8 hrs before I finally got everything to work. Now I am ready to upload the firmware. Uploaded the remote panel tool on my computer, Now I see, MCU update, DSP update and then under this, exit. I pressed both updates then exit. My display on the 6500 inverter disappeared, its no longer lit up nor displaying any information. The instructions and image from eg4's document, showed DSP update "grayed out" hence non selectable. This was not the case for me, it was selectable, so I pressed it. They did not let me know, that I must not press this button, via a Warning, or something, such as " Do Not press DSP update. I have updated software before in Windows for latest updates on my computer systems before. So I thought pressing all updates would be ok, since Signature Solar put me here in the first place. I was wrong. Can anyone ( including Ben, from SS) assist me in resolving this issue in getting my inverter's display operational. I graciously would appreciate it tremendously. Sincerely jfcruz
