Okay. Maybe post your complete configuration for clarity. If these are the only panels you have then I'd absolutely split them. Otherwise your second inverter has no PV input so it can only pull from the battery or grid. I guess this also depends on your source priority settings. Are you SBU or some other option?Thank you for quick reply. I already have 2 eg4 6500 running in split phase and i wasnt sure if its more efficient to aim for higer voltage or amps in adding extra solar to 2nd eg4 and probably not adding more solar panels...
My bad on that. I used the operating voltage above. Yes, use the VOC or 45.5 x number of panels in a series. The only way you would see that would be if you put all 12 panels in a single series. In that case you would exceed the voltage at 546v. So you're going to need to split those into two strings of 6 (or some other configuration to stay under 500v). From there you could combine the two strings of 6 panels in parallel to give you a single string with 273v and 18.68a (9.34 isc x 2). If you exceed the amp rating the inverter will clip it but you don't want to exceed the max voltage. I think my math is right on this. Maybe someone else can chime in and confirm.Yes, sbu with no utility to either inverter. 1st 6500 has 3k on pv1 one 3.4k on pv2. On reaching the max 500 volts on the pv inputs, am I looking at open circuit voltage (49.5) x 12 or optimum operating voltage (37) x 12?
Fuse? No. Breaker - yes I recommend a breaker between each PV string and the inverter. Make sure it is DC rated appropriately for your voltage and amperage. I also installed an exterior disconnect for the panels.I will probably go 6 in series into pv1 and 6 into pv2.... if later I decide to parallel the 2 strings with a y branch into pv1 do I need any type of fuse when using 10 gauge solar wire?
It depends on the voltage and amperage on the PV circuits. I have four strings with a 63a 500v DC breaker on each. These are DIN rail mount breakers housed in an enclosed plastic box with the DIN rail. Here's the type of box I use but there are a lot of options on the box as well as the breakers. Just make sure they are DC rated.Ground mount. All my solar currently goes from solar panel to 10 gauge wire to a DC disconnect to pv imput. What breaker should I be using?
