dmkjr
I have a 6500ex that was set to charge the batteries below a certain SOC through Solar Assistant. However, I had the max AC current set too high and it tripped the breaker that I was feeding the inverter with. When I woke up this morning the batteries were showing 1% SOC but the inverter was still on and running.
I quickly reset the breaker, set to 30a Max AC charge and switched from SBU to SUB mode. The inverter shows that its charging, but all of my EG4 batteries are flashing a red light on the Alarm indicator but the SOC does not show charging on the batteries.
I've contact Signature Solar this morning and they told me to cut off the inverter and let it reset and then turn it back on. Anyone else experienced this issue?
Thanks in advance!
Thanks in advance!
