eXodus
- Jul 27, 2020
- 1,485
Please look at my initial post in this thread. I've been the first to endorse this product. It's really a good idea.Please post a link to the 12k btu heat pumps for $600. I’d be very interested in buying a couple.
And limited use case?
Maybe if you’re in a cold dark place as @Will Prowse mentioned in the video ?.
Most of the western US could use this system nearly year round. And the rest of the country could likely benefit as well, just not as often.
I have a place near LA at about 4000ft elevation that this will be perfect for. 27f last night, snow expected later today, and it is commonly 90-100+ in summer. No shortage of sun except when it rains or snows.
This unit would give me free heat probably 75% of winter days if I panel it aptly. That’s more than acceptable to me.
A portion of the garage was converted to a rec room years ago before I obtained it. It will be a shop / mancave room once the rest of the place is updated and improved.
It’s a 330 sq ft room, with a south and west facing gable roof. New R 30 cieling insulation, and so called “cool” roof (4/12 pitch) with vents, R15 walls (old 2x4 construction), new dual pane windows (2). Thermostat controlled gable attic vent.
That room absolutely BAKES in the summer and is cold ? in winter.
I look forward to keeping that room cool in the daytime this summer with FREE solar energy, and no inverter loss. Keeping it cool all day for FREE will make it easier to keep cool in the evening when temps drop. And I can heat that room for free in winter, and in both hot or cold seasons let the conditioned air migrate to the adjoining areas. I figure the payback period will be under 2 years compared to running window ac units.
When I see this system works well for that room, I’ll buy another for another area of the house, or the 24k btu unit if I can configure 3 air handlers like mr cool and other manufacturers offer.
Hopefully members @SignatureSolarJames and @SignatureSolarAdam will consider developing and marketing multi air handler units, and ALL these units with quick connects like others do. That would make them soooo much more DIY friendly, and eliminate or greatly reduce most faulty install issues.
Imnsho there must be literally millions of use cases for this type of unit in the US.
Pretty much all of So Cal, and significant areas if AZ, NV, NM, TX, and UT for starters.
PS ultimately I’d like to power these units after solar hrs with an all in one inverter and a server rack battery bank.
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/img-20190331-124124-456_1_orig.jpg)
EG4 Heat Pumps?
https://signaturesolar.com/eg4-hybrid-ac-dc-solar-air-conditioner-1-ton/ Anyone know anything about these? Looks like you can connect directly to solar panels too.
![diysolarforum.com](https://www.mobile-solarpower.com/uploads/1/2/9/6/12964626/final-favicon_orig.png)
It is very simple, and for many a perfect choice. You where asking why there is not more interested in this forum.
and I gave you two reasons:Seems like ?Crickets? ? ? on this product, really?
1. Price (f you already got a solar off-grid system - this doesn't make sense adding)
2. We are all geeks here and this is too simple and we want more wires and stuff to mess with
So basically - this board is potentially the wrong audience for this product to address.
All of Florida Facebook Marketplace / Craigslist is plastered with budget split heatpump
For instance:
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
Our proximity to the port of Miami the container ships dock probably make them more affordable around here.
