MrM1
I'm Here, But I'm Not All There
In thinking 6 x 375w panels at 240v dc operating voltage for the 24k. I'd like to think i could 4 of those for the 12k
two of the units I have 3 370 watt mono's and the other 2 I have 4 330 watt poly's , in sun and even in overcast days as long as it isn't dark as night overcast they can run completely on solar. It gets cool at night here in central FL, by cool I mean usually in the 70's and sometimes less, like tonight it's going to be around 49F so I know I won't be using any grid power tonight LOLHow many panels are you using to run each unit?
Thankstwo of the units I have 3 370 watt mono's and the other 2 I have 4 330 watt poly's , in sun and even in overcast days as long as it isn't dark as night overcast they can run completely on solar. It gets cool at night here in central FL, by cool I mean usually in the 70's and sometimes less, like tonight it's going to be around 49F so I know I won't be using any grid power tonight LOL
Yay! Finally input from someone with the 12K units.I now have my 5 ton power sucking monster central A/C units' breaker turned off. Some think the price is high but if you look at decent Mini Splits at say Lowe's or HomeDepot you can pay $1,700 and up. Cheaper models can be as low as $700.
1. YHas anyone actually gotten a 12k and / or a 24k EG4 unit? I have looked at the manual and spec sheet, and written SS, but not exactly seeing what I need to know
1. How long are the actual included copper Line Sets for Each. I'm seeing on 9.8ft for the 12k and 13.1 ft for the 24k. Confirmed?
2. How Long is the Control wire (I saw a video which said it was actually shorter than the copper line set). I'm seeing 13ft for the 12k and 16ft for the 24k. Confirmed?
3. The Voltage range is between 80-380. If I Use 4 panels at 34.4v max power (not VOC) and 335w each panel, that is 137v and 1340w total. Is that enough to get either the 12k or the 24k unit up out of bed in the morning?
Also, in setting up series strings. Do they have to be even numbers or can you use odd numbers? All though odd numbers makes for funny looking arrays
Not using the 8th panel? Yes I did.1. Y
2. Y
3. 12k, Y (24k, you'd basically be running it as a 12k. Not a good plan.)
Series strings odd numbers no prob. Did you notice I said I'm not using the 8th panel on my racks? Makes a great project panel, check Voc , etc. Yes I'm also symmetry OCD as Rocksnsalt said.![]()
Oh BTW ... I can assure you, you have no OCD on me.. Yes I'm also symmetry OCD as Rocksnsalt said.![]()
Compressor only.Are there supplemental heat strips in the EG4 Heat Pumps or is the heat only produced from the compressor ?
Dunnellon area here, so you get colder than us just 60 miles North lolThanks
Yeah I'm 30 min east of Gainesville FL
I installed my Hotspot this past weekend. And had the same issue. It came with a 3 meter line set. I bought a 6 meter one on Amazon for $150. Gotta love next day delivery.Well my 3 arrived today. EG4 mini split heat pumps: 1 12k / 2 24k.
- packaged very well
- arrived no damaged
- build is decent enough
Answering a few of my own questions
- the air duct fins left to right , while not automated, are manually adjustable
- up / down is automated
- but the line sets are a bit of a disappointment. Why is the 1 ton a 5 meter and the 2 ton only 4 meters. Odd
- and they're not swappable. The 1 ton 12k is 1/4" & 3/8" ... The 2 ton is 1/2" & 1/4" ( I need about 16 ft for one of the 2 tons. But I found a guy who will braise on 6 feet extra for $50)
Over all, pretty excited. Probably won't have a chance to install them until mid may, early June
So the line sets are pretty much universal? As long as it's the right diameter? Are the nut fittings/ threads and the flare fittings all the same.I installed my Hotspot this past weekend. And had the same issue. It came with a 3 meter line set. I bought a 6 meter one on Amazon for $150. Gotta love next day delivery.
I was a little worried about the flare nuts being different. But they were the same.So the line sets are pretty much universal? As long as it's the right diameter? Are the nut fittings/ threads and the flare fittings all the same.
You're getting a line set off of Amazon was what I was thinking too until my guy said he'd do it for 50 bucks plus the copper. But the copper might be a fortune I don't know
Yes, between floors.I bet all the short linesets are for sale on ebay lol.
From Tim's build thread if any didn't see:
Post in thread 'My build thread' https://diysolarforum.com/threads/my-build-thread.35602/post-767327
Tim, it looks like your lineset runs in the wall or roof/floor too??
100% agree, especially re multi head units.too bad they don't make a 30,00 BTU or 36,00 BTU. Also would be cool to see a multi head unit for smaller places divided up in to rooms, in any BTU.
But when the head fails, you have zero A/C - heat. Why not have multiple independent units for more redundancy? That way, you don't get caught with your cheese in the wind.too bad they don't make a 30,00 BTU or 36,00 BTU. Also would be cool to see a multi head unit for smaller places divided up in to rooms, in any BTU.
There are are +’s and -‘s to both options.But when the head fails, you have zero A/C - heat. Why not have multiple independent units for more redundancy? That way, you don't get caught with your cheese in the wind.
