EG4 rack battery, recommended charge settings?
JimGSolar
Minnesota
EG4 6000XP, EG4 LiFEPOWER batteries in a rack, with bus bars. Communication is working fine, battery firmware updated. Battery type is Li-ion, brand 0. In the battery owners manual it tells bulk/absorption 56.2V, Float 54V.
In the Monitor Software on the PC, it doesn't appear these values can be accessed. Also, as I look at the manual for the 6000XP, it doesnt appear these settings are available at the little front panel either. So, are these settings hard coded into the system? Is there anything I need to do besides what Ive already done?
I thought I saw someone, somewhere say something about changing a setting to 20% instead of the 15% default (max discharge?). But I just checked setting 11 and I couldn't set it to 20% on the inverter.
Right. I believe mine won't accept any setting except 15%.
