Electrical Schematic for Camper
acampernamedsue
Austin, Texas
Building a small solar system for a 1988 slide-in pop-up camper: 200W solar, 100ah battery. Attempting this with the MPP Solar 12V 800W All-in-one unit (PIP-812LV-MS). I was hoping that a few of y'all could review my "rough draft" and point out any potential issues. Any & all feedback very much appreciated. Cheers!
- Jeff
Should I connect the Master Battery Disconnect Switch between the Battery & +Busbar? Or between the +Busbar & Fuse Block? And can anyone offer any input as to what size fuse they've used this this model PIP? MPP's website and manuals are a bit vague. This is the best I can find:
This unit will go in my FR TH 26 RR. I just plan to add a off grid/shore power option to power the AC needs.
I believe the BB can only push 100 amps. internal BMS limit.
How much DC loads do you plan to run?
I believe my DC panel has a 40 amp fuse in the main.
