Burgh60
I have some questions on suggestions on what to use. This is my first venture into Solar.
The original electric has been removed so I am starting from scratch. I know I can add a Power Center. But I didn’t want to put that in and add Solar later. In my mind I have a clean slate and might as well do it right from the beginning. I question whether I need a power center like a Progressive Dynamics PD4100 if installing solar also. The electrical upgrades and existing devices I have installed and wired so far are listed below.
So do I install a Power Center then incorporate the Solar part into it?
Or do I start out with Solar and wire my AC circuits to a small panelboard. And install one of the Fused Circuit boards for the DC?
I have seen some bad reviews of the Renogy product.
I looked at the MPP 1012LV-MS Product as an all-in-one unit. It appears this needs to be mounted vertically which may be a problem for me. I also was unsure if this could be used to supply 12vdc also. I guess it defiantly could feed the Power Center.
Any system or product specific suggestions would be greatly appreciated.
Also, I am a Licensed Journeyman Electrician so I know how to wire various components and size wire. Just looking for a good solid recommendation for starting from scratch and doing right.
Thanks in Advance!
- Two new LED main lighting fixtures.
- Four small 2” diameter recessed LED light fixtures.
- Five 120vac receptacles (The original camper had one).
- I have installed a 12vdc water pump for Boondocking.
- I have installed a new 12vdc Vent Fan.
- I have an existing furnace that has a small fan rated 12vdc.
- The refrigerator is gone as it didn’t work. I am debating if I should put a frig back in or not. If I do I am not sure if I will do a 2 way (120vac & 12vdc) or a 3 way (120vac & 12vdc & Propane) Finding one that fits and the price can be a challenge.
- I plan on installing a 12vdc car radio also.
- If I add an AC unit I would only use that at a camp ground with shore power
Thanks in Advance!
