The picture is from while I had the negative wire disconnected.
a number of issues shown in the picture.
No main fuse or breaker shown near the battery positive, for a 1500 inverter need to be 150 amp class t or MRBF.
The 40 amp breaker shown, ( in the controller panel feed) are not very reliable especially the cable clamping.
Reading all your posts, it seems you have unfortunately taken on a system installed by others and have, due to inexperience, attempted to use far more power than generated, thus depleting the batteries.
running for about a week with 100% battery continuously according to the charge controller.
The battery state reading on the Renogy solar controller is very inaccurate, you need a battery monitor to accurately show SOC.
This is not enough to run a fridge and totally useless for the other high power AC consumers . If your location is New England you wont be getting much solar at this time of the year.
Its has not been discussed, but you need additional charging for your batteries, from the vehicle alternator via a B2Bcharger, from shore power, from much more solar, ( as much as will fit on the roof), from a petrol, propane or diesel generator set with suitable AC to DC charger.
Until you redesign your electrical system opt for diesel or propane heating and cooking and a generator for electrical power
Renogy batteries are not too bad but have unusual protection features that can cause issues. Renogy products like solar controllers and inverters are not very reliable.
Disconnect the all the cables that make up your battery bank and attempt to 'wake up' each in turn.
try one of the following in turn until you have a result ( the result would be to see an increase in battery volts and the ability to power a small 12v load)
1) connect the Renogy solar controller to the battery, switch on the panel breaker, (assumes you have some sun).
2) connect a dumb battery 12v AC battery charger
3) using jump leads connect to the vehicle 12v starter battery ( confirm its 12v, some vehicles use 24 volts).
Good luck with solving your issues, there are many helpful guys on this forum prepared to help but its difficult to carry our system diagnosis remotely. You can help by giving as mush information as possible, pictures, diagram, equipment types and model .
if its any consolation I have encountered many situations where newcomers to RV and Boat 'living' face issues similar to yours. Eventually all is sorted, expectations may have to re-evaluated and compromises made.
Mike
