NewGuy23
I have 4x12v panels in parallel feeding a Renogy Rover 40amp charge controller. For five years, this has been charging a bank of 2 x Renogy 200ah gel batteries in parallel, wired to an AIMS 3,000 watt inverter. Everything is 12 volt. This is a dedicated system that ONLY runs my well pump, which pulls 10.5 amps when it's running. Sometimes, it runs 2 minutes a day. Sometimes, 6 hours a day. I've had zero problems.
Yesterday, I replaced the batteries with one LiTime 100ah Mini LiFePo4 battery, and switched the charging profile to lithium. Immediately, the voltage would spike as high 17, trip an alarm that disconnected the CC, then it reconnects, spikes, alarm is triggered, rinse and repeat. I only let this happen 3 times and disconnect the charge controller from the panels.
Can anyone shed some light on what happened here?
