Joseph sapia sr
- Apr 25, 2020
- 37
Good morning everyone. So I built this 1660 Pelican case set up, using 200 amp hour renogy hybrid gel battery with 20 amp Rover Elite mppt controller. 1500 3000 Peak Cobra inverter, well I'm thrilled to say I just bought my first hundred amp hour battleborn battery question is should I pull out the two hundred amp hour renogy battery replace it with the battleborn hundred amp hr? And I know my solar controller has the setting for this battery chemistry, wondering if this 20 amp controller will be suited for this battery and if my NOCO genius 10 amp charger is good to charge this battery as it's built into the box? Thank you all so much. Will try to post a link to what I built maybe you will have a better understanding a picture is worth a thousand words. Thank you for any information..
