Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,681
Do you mean to replace a failed bypass diode in the panel?
Current should be at least Isc, higher would be better for margin, like 20A.
1000V is more than enough. If 2 diodes in a 40Voc panel, will never see more than about 20V. So a 40V or higher diode would be fine.
The trickier part is power dissipation, which probably caused the previous one to fail. Not much way to get rid of heat. Higher current diode wouldn't heat as much with only 10A flowing. I think a lower voltage diode (not 1000V) would probably have less voltage drop, less heating.
Or do you mean to use outside the panel, as a reverse-protection diode? Maybe for EMP protection?
