derbuechsenmacher
- Apr 19, 2022
- 13
Last year I installed an additional 9kw to my existing 11kw solar setup. The new system uses enphase micro inverters. I am considering adding battery to the system and I know I need to do an ac coupled system. I've read tons of forum posts and watched countless videos. From what I can tell, I essentially have to feed the enphase 240v output into another inverter/charger which would charge the batteries (the enphase basically is the grid input) and then have the new inverter connect to the panel. Am I remotely close here? How do I ensure that the batteries feed power to my house instead of the grid? I'm assuming that I really need to connect the new inverter in parrel with the enphase since the enphase won't output unless it sees power from the grid. I don't want to go with the enphase battery system as it seems to be overpriced. When determining to go with the enphase grid tie system, I did evaluate whether to just build it off grid, and the enohase system was onlu about 3k over the dyi and I did not have to do any of the work (yes I could have gone cheaper on the dyi components, but I speced the best I could find since reliability is critical). I dontt have what I speced handy (can't find the docs on my computer). So please don't ask
