wheisenburg
Independent Solar Consultant
With their newest firmware version 521-00005-r06-v02.61.01 the Enphase IQ8s are now able to AC couple with Schneider XW Pro inverters. I had a 35 panel IQ8 grid tied system installed in Aug of 2022. I added a battery backup to the system in Dec 2022. While the system did work fine as a UPS backup system, I was never able to get the IQ8s to produce power when operating off grid. This of course meant that in the event of a grid outage, my available power would be limited to whatever was in the batteries at the time of the failure. Alternatively, you could still charge the batteries with a generator.
I was never looking for a totally off grid solution. I just wanted something that would work OK during an outage. I still wouldn't recommend this configuration if you are truly building an off grid system. For that DC coupled is definitely the way to go. For adding back up to an existing grid tied system, I would say that this is now a solution that will work "Good Enough". Now at this point I have not done extensive testing, but I have heard from at least one other person that they also have this configuration working. I can't say for certain that all the issues are completely solved. I can say that it wasn't working at all and now it does. This is huge progress in the right direction
One thing I have learned in all this, is that just because a product advertises that it will AC couple, does not mean that the configuration you are planning to use will actually work. Manufactures (and retailers too) don't really maintain any type of list that says these PV Grid Tied Inverters will AC Couple with this Hybrid Inverter.
I'm actually mostly happy with the Enphase IQ8s. They are efficient. They are reliable. Their software works well. I had two goals for this system. First generate most of my own electricity and insulate me from future rate increases. Second, provide me with more reliable power so that my house could at least temporally operate independent of the grid.
The Schneider XW Pro 6848 Inverters are also great in terms of the hardware. They have great surge capacity. They handle out of balance loads. They are rock solid and reliable. The software however, is kind of a mess. It is like they layered features on top of features, without really thinking things through. There are hundreds of settings that interact in unexpected ways. If you wade through the configuration process and get everything sorted out, good for you. Luckily I have full net metering. I can push power to the grid and pull it back later for zero cost. I am not trying to do any time of use load shifting or self consumption. My inverter simply needs to sit there and do nothing until there is an outage. Then it should take over and produce power. It was still quite challenging to get this basic configuration to work. Getting it to actually recharge from solar when off grid, was certainly a goal, but even without that working I was still better off. Now technically, it was the Enphase inverters that were refusing to turn on and stay on. The comments on the Schneider software are still applicable.
In reading through this forum it appears that many people are having trouble setting these XW Pro 6848 Inverters up for things like:
In any case, I feel like I have made a major break through today.
- Zero Export.
- Grid Sell.
- Peak Shaving.
- Time of use shifting.
