Gravelproof
Hi all,
I have an Epever Tracer AN 20A MPPT controller, and yesterday after adding another panel into my grid (now 4 x 100W) I noticed something odd..
The panels were in series putting out about 95V which I know is close to the 100V max but hadn't quite reached it, but I saw that the amps on the controller had dropped to 0.
You can see from the graph below that it didn't drop the amps at max power, but later on.
I went and reconfigured the panels into a 2 series in parallel, and reconnected the panels, and saw that it was showing around 36V and ~4A... after an hour I checked again and saw that again it had dropped to 0A.
I turned the panel off and back on again, and it jumped back up to 2A or so...
In the past I have had issues where I have had things plugged in for a long time and the batteries have drained and I always assumed that it was because I wasn't generating enough power. Now I wonder if this issue with the controller has been happening for a while. For some reason it will sometimes just drop to 0A.
And it is not that there isn't any load on the system.
In one case I was pulling 45W and it wasn't providing anything till I disconnected the panel input and reconnected it.
Can see here this log from the Venus OS that is logging the Epever data. It was sunny with no shade during all those gaps by the way.
Is this an issue with the Epever controller and I am best getting rid of it, or is it a nuance that I need to resolve that might be related to something else in my system and swapping out the controller won't really help?
The controller is charging a 100Ah Lifepo made by Ecoworthy, and the load is a Renogy 1000W Inverter, there is a Victron Smart Shunt and Smart Battery Protect in there too.
