Hey, I have an EPever MPPT that I use to charge in the field, I have 2 batteries, li-ion 4S battery and 4S lifepo4 battery.
I use MT50 remote meter to control it with a custom battery settings. Since there is only an option for a single custom battery, in order to charge each battery I need to change a lot of configurations each time. I wonder how I could overcome this issue, I thought of maybe buying another MT50 unit, but I'm not entirely sure if this would do the trick.
I also saw one of these wifi dongles for the MPPT(like these https://www.aliexpress.com/item/32713275526.html) which I also wonder if could do the trick without having to change units.
If someone have any experience with this I'd like to get some suggestions on what would be the easiest cost-effective solution for that. Thanks
