Here is the 48v LF280k Battery Build I am planning on:
- 16 LF280k (nominal 3.2v each). Assumes the dual M6 terminals.
- JK BMS 8-24S-200A continuous, 350A Peak, Active Balancing JK-B2A24S20P (B2A: 2A active balance, 24S: up to 24 batteries in series, 20P: 200A power continuous).
- JK BMS Power Switch or Monitor with Switch
- JK BMS-RS485 (if you want to monitor with Solar Assist)
BMS: Want Active Balance for cells that large.
- Class T Fuse Holder
- Class T Fuse (250 amps?)
- Shunt
- Optional: On/Off Switch (400A, 60V DC Rated)
- Something to mount the BMS/Fuse/Shunt on
For the JK BMS:
2 M6 (1/4 inch) Ring Terminals (Main connection to Battery)
2 M10 (3/8 inch) Ring Terminals (to connect to Shunt)
18 M6 Ring Terminals (to connect all the small wires to each cell
For the Shunt:
1 2/0 Wire with M10 ring terminal on one end. Don’t know what the Growatt has.
For Optional On/Off Switch:
2 6 AWG wire with M6 ring terminal on one side, and M10 on the other (to connect to Battery).
1 2/0 Wire with M10 ring terminals on both end (to connect to Fuse Holder)
For Fuse Holder:
Fuse: The Blue Sea Class T fuse has a long delay near the rated amperage for blowing. At 110% of rating, it should be able to go 15-30 minutes before blowing. I may draw up to 275 Amps with my inverter, but that is only if other batteries drop out, and I am running everything. Otherwise, I anticipate drawing 90 amps (0.3 c) max, and more likely 30 amps (0.1 c) max sustained rate.
Optional:
- Pre-charge resistor
- Crimper for Ring Terminals (for the BMS).
- For the larger wire, you would need a larger crimper, or buy pre-made wire.
- Flexible Busbars (reduces strain on battery terminals from expansion/contraction of batteries)
- Insulators (electrical) between batteries.
- Power supply to charge/balance the batteries
- Something to box/compress the batteries. Lots of conflicting advice regarding compression. It will be hard to measure compression force. But a rigid box may get close enough. 300kgf (661 lbf) is recommended for EVE LF280K. I found these springs on Amazon (one of the few with force/mm info): https://www.amazon.com/dp/B07GSNCYNK/
Assembly:
Battery - <> BMS <> Shunt <> Inverter
Battery + <> On/Off switch <> Fuse <> Inverter
- Wire batteries in Series, and connect BMS.
- Download JK BMS app, and connect to battery (DO NOT CHANGE PASSWORD – known problem with app).
- Setup parameters for 16 battery full charge. Make sure it all seems about right (cell voltages, etc.)
- Pre-Charge up to full (somewhere between 54.4v (3.40v per cell) to 58.40v (3.65v per cell)). I would do 57.6v. I have a Chargeverter, but could also use the Inverter. If you use the inverter, follow proper procedures to connect (pre-charge resistor).
- Let battery charge until BMS does over-voltage disconnect.
- Immediately after cutoff check individual cell voltages (if you wait, batteries will settle, and no longer be a good indicator). If within 50mv (0.050v high to low), then skip top balance. If 50-150mv, then your choice. If over 150, then need to top balance.
- Top balance: Use BMS: Float at 54.4v until all the cells are balanced. Otherwise: Disconnect everything, and wire cells in parallel. Charge with powersupply at 3.50v to 3.60v. Follow top balance instructions for detailed instructions and cautions.
- No need to bottom balance with BMS.
- Reassemble (if necessary), and adjust BMS Settings for normal operation (high/low limits)
- Connect to Inverter (follow instructions regarding pre-charge resistor).
- If connecting with other batteries, charge all batteries to the same voltage before connecting together.
