Anything else recommended for this EVE 48v 105ah build ?
KnobCountry
Leg puller. Zap avoider.
Behind the pond.
See attached pic
16 EVE 3.2v 105ah cells that come with screws and busbars
JK 150A BMS with bluetooth supports 8-24 series balancing
already have inverter, smartshunt, 4/0 battery wires
Anything else recommended for this 48v build ?
The price is way better than any 48v batteries that I can find like eg4, litime, etc. but maybe I missed something ?
To compress them ? I hadn't decided. Is a compression strap or 2 sufficient ?
Would 1mm thick pieces of plastic work in between ?
Yes, 1mm thick plastic would work.
To compress or not to compress, that is the question. There are long discussions on the subject. I am not sure it is worth the effort to compress properly. Some sort of fixture, to hold your battery might be beneficial depending on your use and setup.
I think I'm going to use some sawed down cheap hdpe cutting boards on each side and compression straps then put everything into a box with casters. I'm not planning on compressing too much, just snug to keep everything solidly together.
