EVE are the cheap cells?I will be extremely surprised if either of these cells last 10 years (3650 cycles) if they are used daily to 80% DOD.
The manufacturers are using extrapolations of their testing that don’t reflect actual useage to come up with a figure for cell life.
When i first saw these types of cells i was excited about the price breakthrough. A few years later and i’m already seeing enough failures to prevent me purchasing them.
Obviously time will tell, but i’d be planning for six years tops for system life if you are using cheap electronics and cells.
Winston / Sinopoly / CALB CA / GBS are the only easily available cells i have seen last over 10 years in service.EVE are the cheap cells?
What do you recommend.
Why not ? We have winston cells from CZ warehouse that were delivered in 2014. Still about 94% of capacity and just 2 years to go to proof if that is right or not.I will be extremely surprised if either of these cells last 10 years (3650 cycles) if they are used daily to 80% DOD.
Be carefull cause there are a lot more than just LF280 cause EVE had also sold LF280M if I remember right and people quite often to forget about the last letter which is important cause only that determines size and chemistry. The LF280 , LF280M and LF280K come in different shapes / sizes, one ist a bit bigger than the others cause it has caused a lot of headache once we realized the difference after arrival of the second batch cause the bus bars were no longer fitting.Look at the specs seen on the EVlithium site and see if it applies to your application:
LF280 - 1C max charge / discharge LF280K - 2C max charge and discharge
EVE LF280K 3.2V 280Ah LiFePO4 Battery Cell
EVE Brand New Grade A LF280K 3.2 V 280ah LiFePO4 Battery Cell With 6000 life cycles and 2C discharge rate.www.evlithium.com
Their cycle-testing methadology is also published. At least they are honest about it! Basically back-to-back (30 min rest between charge /discharge etc) simply beating the calendar-age clock for our application.
So instead of trying to predict the future, you can make some sort of evaluation as to how they are spec'ed and tested NOW.
HONEST. I like that. But you can see if one is just "shopping the cycles" and not taking into account the true nature of their own application, this can only serve as a "guide". YMMV.
No, not at all cause you misunderstood the important points cause calendar aging referrs also usually to having 80% of initial capacity.As I understand these batteries both calendar age out at 10 years. Let me know if this is wrong.
So if the LF280 is cycled 100% daily (it won't be) it would still calendar age out at around 10 years.
Why pay 30% more for LF280K?
Thx
II bet they will over deliver a lot above 80% in 2 years and I am sure they will even last a lot longer then.
Of cause they are vastly different but these were the first LiFePo you could get back then and they still do a great job but will be sold when they reached the 10 years.Winston cells are vastly different to EVE cells.
