I'm not sure what material your climbing rope is made of, but if it has any kind of polyester fiber, which most of the cheap ropes do, I would highly discourage this plan. The ropes will work fine for a few months. After this, the polyester will have deteriorated enough in the sunlight to weaken it, making it no longer safe. After a couple years or so, depending on its thickness, it may just blow away in the wind on its own. Most types of plastic are vulnerable to sunlight. A steel cable would be more secure, and it would probably be more aesthetic, too (less noticeable).Mine are not attached AT ALL
I DID comment that these were my Gypsy panels. They weigh 42lb a pop plus the 2x4 structure so a solid 50+lb per set. I will add an eye loop at the bottom of each and run a long fake rock climbing rope (the ones you find at home depot for 20/100' and are 1/2" diameter.... I will connect to the bottom of each triangle structure and anchor on the side of the house at each end. If things go really bad (i.e. hurricane winds), then the tripod might topple on the roof but no 50lb panel will go flying off the roof.
Note that this perspective is shared from Thailand where the sun is more intense and perhaps the quality of products is less--so your mileage may vary--but I have seen ropes destroyed by sunshine here.
