littleharbor2
The Midnite MN 3024DIY keeps charging when the inverter is shut down. The higher max Voc models don'tI would stay away from the "all in one" units. Youll want to switch it off when you leave, but then the solar is also off... . If you switch off an all in one unit and you have say 50% batteries, you return to 50% next weekend, not ideal.
Having a stand alone charge controller recovers and keeps your batteries full when youre gone while the inverter is off. Then you start your next weekend on full charge.
Maybe someone knows of one that keeps solar on? Otherwise a traditional LF inverter charger with separate mppt would serve you well.
Im a fan of Aims products for off grid cabins on a budget but im a tad biased on that. Victron and Outback are top choices as well (just pricey) and will last for years.
