Bluedog225
Texas
- Nov 18, 2019
- 3,226
I’m noodling around on a little project. I’d like to make a little motion sensor or dusk activated, solar powered LED light fixture.
And I’d like it to be maintenance free for 20 years or so. Essentially the life of the solar panel.
I’m going to put it into a steel box for it so the internals will be protected from most elements, but not from hot and cold.
Is there a battery up to this task?
-Long lived
-Not bothered by full discharge
-Not bothered by 140 eff heat
-Not bothered by use or charging when freezing
-Ideally it could be charged straight from the panel without a charge controller. May require some careful planning of capacity and panel size.
-Capable of 4000-5000 cycles.
-In the neighborhood of 100 watts would be a minimum.
Thanks
-Long lived
Thanks
