MikeMynis
- Apr 21, 2022
- 53
Hi guys, I have 1 Growatt SPF5000ES with 9 450 Watt solar panels and a lead acid battery bank. It works okay, but we need more power.
So I bought 8 extra panels each 550 Watt plus an extra Growatt SPF 5000 ES.
According to the Growatt documentation, I can parallel both Growatts, extending it to a 10kW output system.
For this to do I need to parallel the grid AC input to both Growatts. I also need to parallel the outputs to the loads, and set both Growatts in parallel mode via the menu, after connecting the communication cables between them.
Then I also need to parallel the battery to both Growatts.
This is the preferred setup according to the docs.
But I don't want to parallel the battery bank to both Growatts.
I want a separate new battery bank (LiFePO4) to Growatt #2.
(and keep the Lead Acid battery bank connected to Growatt #1)
So each Growatt has their own solar array and battery bank connected.
The grid inputs are paralleled and so are the load outputs.
Is this okay to do? Anyone having experience setting this up?
Thanks,
Mike
Thanks,
Mike
