vinthewrench
- Jun 25, 2021
- 28
Hello all;
I am trying to build a system to keep my home running during power fail without having to start
up the generator constantly. My strategy is keep up most critical loads on battery/inverter and
run the generator periodically to recharge.
My first attempt at using modern charger inverters combo as a UPS to power my internet setup
( Starlink, Unifi, a bunch of cameras and Raspberry Pi projects) independently from the rest of the home.
I have a pretty simple setup here, a Xantrax Freedom XC 1000 hooked up to a BattleBorn BB10012 100 A LiFePO4 battery,
I am also using a Victron Smartshunt to track how well the battery is doing.
The Starlink dishy uses a ton of power(150W) , when the entire network is running including the POE cameras I have seen it go
between 160 to 260W. Given the current setup the smartshunt quotes me about 6 - 8 hours of backup.
Not bad, but I might add an other battery. This is OK for a first try, On retrospect I probably should
have used AGM batteries instead.
For those who know the Xantrax I have set the following parameters on the config.
02 LBCO voltage (11.5)
13 Shutdown recovery (Auto)
20 Battery Type USE - custom
22 Absobtion V 14.4
23 Float Voltage 13.4
The one quirk is that even though the battery is at full charge and the I am running on utility/shore power,
that the fan comes on from time to time. I have mounted the Xantrax where it is well ventilated.
I suspect what is going on is the Xantrax charger is trying to keep the float voltage up?
Is it possible that the smartshunt is what causes the battery to keep toping off?
I wrote Xantrax customer service (i'll post a reply)
If I want to keep this quieter or maybe have the fan run less often can I simply lower the float voltage?
any ideas?
22 Absobtion V 14.4
any ideas?
