Hi
Sorry not so much a Solar question but wondering what charging methods people use For their lifepo4 cells?I have a dedicated 20amp ac wall outlet to work with. Id like to charge my diy 72v pack as fast as possible and would like to hear what options are available. I don’t see a victron charger for 72 volts. Any advice is appreciated. The rough specs of my build are below.
Im building a 72 volt golf cart pack out of 24 ninthcit 3.2 cells on Amazon
[ ninthcit 3.2V 230AH LiFePO4 Deep Cycle Battery Cells with Iron Phosphate, Grade A Replacement Automotive Lithium Motorcycle Batteries with QR Code, Perfect for Boat, Marine, Golf Cart, Camper(4PCS) https://a.co/d/erEH5Ct ).
I’m wiring it with all copper connections to reduce resistance and a…
DALY Smart BMS LiFePo4 72v 24S 400A with Programmable Bluetooth Module and Common Port Cooling Fan
The golf cart has an upgraded 600amp controller that’s computer limited to max draw 250 amps pulse not to overwork the pack.
