DIYrich
Solar Wizard
I have a Sol-Ark 15k, and due to Utility Limitations, I am restricted to 25kW, so paralleling a 2nd 15k is not an option. Utility won't accept "soft" 25k export limit through programming.
I'm thinking of putting the new Growatt SPH10000TL-HU-US into the Smart Load port of the Sol-Ark, and moving a few heavy loads to the Load port of the Growatt.
In addition, I am enrolled in the State's Energy Storage Solutions program, so the more I export from Battery to the Grid, the more rebates I get. I can move PV to the Growatt, and have it charge the battery at the same time the Sol-Ark takes from the battery and exports to the Grid (the ESS program somehow gets a report from the inverter). There is something in the program about not curtailing Solar PV in order to export more, so the Growatt avoids that problem.
While on-grid there shouldn't be any problem. I have 1-1 net metering, so Grid will support loads on both inverters. When the Battery is full, the Growatt exports through the SA's Smart Load port.
When grid down, UL1741SA should limit how much excess PV the Growatt sends back to the SA. During an extended grid down, I will change the Growatt setting to use battery before grid, and that should free up some capacity for the SA to support other loads.
Any issues that anyone can see?
