Welp, I finally wired in my multiplus! I used Tom Morton's wiring idea for a contact switch. The switch disconnects shore power and bridges L1 and L2 for the multiplus to feed. I ended up buying 6/3 wire at HD and extending the main shore feed over to my battery bay, and a return run to feed from either shore or the inverter. I even managed to run an A/C in testing, but will be adding soft starts in the near future.
I need to finish up wiring the shore to inverter feed, but decided to get a couple more cuts of 6 gauge from HD rather than cut up the remainder of my 6/3 that I can use for other things.
So the inverter use cases that this will support:
In the end, I can create 12 volts from either my 24/12 converter or turn on my power converter in a pinch. In general I just leave it turned off but in the event hardware failure I can give up efficiency as needed. Heck, sometimes I turn on the power converter to let the battery bank charge faster off solar.
- Stand alone - all solar
- Hybrid - add inverted power to shore/generator power - L1 and L2 bridged to the box but NOT toward shore - shore can be 50a but it'll only use one leg to power the inverter.
- Full shore power - inverter bypass, shore power goes directly to the panel like the factory intended.
