John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Ok, In that case maybe it can provide ~20amps @ ~29.2 volts10awg
On most balance chargers the balance current is 1A to 2A. The balance leads themselves don't need to be as large of AWG.Ok, In that case maybe it can provide ~20amps @ ~29.2 volts
The power supply is only 10a so probably can’t get anymore than that.Ok, In that case maybe it can provide ~20amps @ ~29.2 volts
Def bulk charge firstOn most balance chargers the balance current is 1A to 2A. The balance leads themselves don't need to be as large of AWG.
Agree but I was talking about the main charge leads.On most balance chargers the balance current is 1A to 2A. The balance leads themselves don't need to be as large of AWG.
do you think 8s 24v 50a Daly BMS is the correct size for this battery?Agree but I was talking about the main charge leads.
Assuming the cells are rated for 1c continuous discharge rate which is 30 amps, yep I think its right in the sweet spot.do you think 8s 24v 50a Daly BMS is the correct size for this battery?
I can't say with certainty but its not the first time I've seen this.yes 1c
also, why is the end of discharge voltage so low at 2.0v? should these cells be 2.6v?
ok thank you!I can't say with certainty but its not the first time I've seen this.
My best guess is that these are either old cells or cells of an older design.
The 5mohms is also atypical.
For the record typically the min voltage for a lifepo4 cell is 2.5 not 2.6 volts.
can you explain the internal impedance is layman's terms?I can't say with certainty but its not the first time I've seen this.
Not really.can you explain the internal impedance is layman's terms?
great thank you!Also worth noting that smaller cells often have higher resistance/impedance than the giant 280Ah cells. Pretty common for the low capacity cells to be in the whole numbers of mΩ vs. the .15mΩ common to 280Ah cells.
