ChrisClutch
I have a 8'x8'x8' R-20 Structure.
(I can go to R-30 if I have to)
Looking at a simple, easy to use system for off grid Heating and cooling.
I am really surprised there is not plug and play outside the toy junk I see on amazon. (sorry to be negative)
I was looking at this option for heating and cooling since it is available in DC voltage:
https://www.rigidhvac.com/micro-dc-aircon-cool-heat (I have NO affiliation with this group). Put this (https://www.) in front of this rigidhvac.com/micro-dc-aircon-cool-heat if you want to go to RigidHVAC.. (I am new here and do not want to break any rules.
I assume I can get a quality 400W+/- for $250 each. Use 3 of these. Bring in a 1000Ah battery.
Yes, mounting brackets and of course this will have to run the 4 LED bulb in the unit and offer a USB plug in.
I assume I will make a "hot wall" or a mounting section/
Thoughts, has anyone priced this out? $700 for the 3 panels, $750 for the AC/Heat unit, LiFePO4 battery? Deep cycle?
This is where I get a bit lost.
Here are the specs on the Micro AC unit:
DC Aircon DV1910E-AC/H
Capacity: 450W (1,535Btu)
- 12V DC
- 5.0 kgs/11.2lbs
- Refrigerant: R134A
- Compressor: QX1901VDH
- Working Amps: 1~8A, (Maximum 25A)
- Size: 355*170*356mm(14*7*14inch)
- 24V mini compressor to enable peak performance
- The airflow rate at the cold air outlet: 28.3CFM
- Heating Option: PTC Heater
- Cooling Capacity:
Cooling: 450W (1,534Btu)
Heater: 300W (1,023Btu)
