voland
Good day,
This is my first post so please forgive the wall of text…
Im primarily looking for validation of my assumptions and some opinions if I am not thinking about this correctly. Keep in mind that I am fairly new to this and I will be doing a lot of reading and watching youtube for information to gain better understanding of these systems.
Background and data Ive gathered so far
Im building a new house in a very rural part of Texas and I am not 100% sure how reliable the power situation is going to be. My goal is to have a solar system that can run a large portion of the house during the day to offset my electric usage, under optimal conditions. Additionally, I would like to have enough battery capacity to heat/cool a bit of space for 3 days, in case of an emergency/power down type situation. Assuming some sunny days, I would like to have this system run pretty reliably "indefinitely". By that, I mean as long as the battery life cycle will permit. Yes, the pessimist in me wants to have a plan B…
Under normal conditions, my current and fairly inefficient house, used 7.2 kWh during the highest use hour of the highest use day which used a total of 129.8 kWh for the day. I expect this house to do a lot better since it will be better insulated, have more efficient HVAC systems (likely heatpump) etc. Nevertheless, I am basing my calculations on this…
The house plans allow for roughly 22 panels to be deploy with a south/south-east exposure(~150 degrees).
Using 400w panels, I should be able to achieve a peak ~8800w give or take a few. I can see about getting higher producing panels but lets use this for the sake of my calculation… I would like to have some extra panels in the garage that I could add in case of a prolonged grid down scenario to augment the system so I would get larger inverters than needed to handle the extra panels. Eventually, I will have an electric car, so I would like to wire up the charger to allow to backfeed from the cars battery too.
Below are my estimated loads I got using a simple load calculator and Im not sure how accurate are the ratings for the devices…
This is what I would consider to be a high running load that I could see during the day. Looks like my max load would be approximately 5.2kWh
This is what I would expect to run during a grid down scenario where I would have to rely on battery power to provide coverage after "dark". Looks like I would be using approximately 4.7kWh per night.
Based on these assumptions, here's the system that I am proposing…
22 400w panels on roof
8 400w panels on ground (if needed)
12 kWh inverter
14 32 kWh battery bank
charge controller (not sure what kind yet)
My "off grid" loads would be wired to a critical loads panel that would be energized by the battery bank
Optional 14kw propane generator on a 1000 gallon tank to charge up/run the house to help run the house while the propane lasts?
Questions:
1 - Am I even close to on target or am I talking nonsense?
2 - I was going to use a high efficiency 12000 btu heat pump for my heating cooling needs. I was thinking of doing a dedicated ductless system just for the master bedroom which is the room Ill want to keep heated/cooled. Would it be better to use a ducted system and heat/cool the bathroom as well? Should I look at other options?
3 - Fridges and Freezers don’t really run 24x7. They cycle. Does the kWH rating means its running non stop? Should I be using a % of that load for my calculations?
4 - What should I reasonably expect to generate from a 400w panel on a 12-12 slope facing south/south-east on a sunny day?
5 - If you read to this point, and you had similar requirements, would you do anything differently?
Thank you in advance for everyone's time and comments!
12 kWh inverter
Questions:
