Hi All, thanks in advance for any assistance.
First RV setup 2008 Lance 825 truck camper with 3x100w flexible Newpowa panels, Victron 100/30 charge controller, Giandell 1500w inverter, 2x100ah Weize AGM 12v batteries.
My main question is about cuttoff / breakers / fuses before I hook everything up. I'm not totally sure if I should use the panels in series or parallel but I figured parallel. The short circuit current of the panels is 6.29amps, volt pmax 17v, max fuse 10a. I bought 3x 10a inline fuses to go with each panel. Not totally sure if that sizing is correct.
Then I bought a 30amp fuse (or should it be a breaker?) for between the controller and battery.
I'm reading I should also have a breaker or cutoff between panels and controller. Not sure if that's accurate or what to get. In all cases I would like to have whatever I need on hand if I should decide to switch panels to series, or if I add another 100w panel and do a series / parallel combo.
Is there any reason other than cost to ever use a fuse instead of a breaker?
Is there anything else I'm missing? Apparently the inverter has built in fuses. I bought a 150a breaker before I was aware of that. I'm still pretty damn confused overall because it seems every tutorial video has different info. I also have a battery monitor I need to wire up. Somebody said I need a 200a relay between the inverter and battery 'to protect the wire' (which is confusing me more).
Any and all help is appreciated. Please dumb it down for me because this is all new including most acronyms.
Thank you
Thank you
