whatismouse
- Oct 11, 2020
- 76
Just got a system up and running in my rv with an MPP 3048lv-mk. I'm new to this stuff so I have a few random questions:
I have float set to 54.4, is it normal that there is almost always 1 amp and sometimes even up to 3 amps of charging occurring in float mode? I was under the impression that LFP batteries drain so slowly, that a "trickle" charge is hardly necessary.
I tried turning float down to 48V because I wanted to see how my batteries would behave without any charging. Would they lose voltage quickly? What voltage would they settle at? Maybe I could get some clues as to why there is constant amperage in to keep them at 54.4V....
As soon as I turned float down, 14 amps started coming out of batteries (previously 0). This would correspond with 100% of my loads being powered by battery, even though I was plugged into shore and with utility set as priority output. Was my inverter prioritizing battery until it lowers down to float voltage? Why?
I actually don't know how to turn charging off just to let batteries rest to see where they want to rest at. Unless I turn off Inverter. Minimum AC charging setting is 2 amps.
Does it make sense to have the float voltage a bit lower, closer to where the batteries would naturally return to from a full charge? Or if they can't sit at 54.4V without constant charging, is that an indication that my batteries are not performing as well as they should? Or is this totally normal behavior?
