Flooid Cascading Heat Pumps
Also saw it and thought, "Multiple pumps, and they have no money to get this certified. They need to sell out to someone." Then I saw that they're using all off-the-shelf parts and I thought, "Hmmm... Any real IP there?"
I dunno... Seems like a nice topic for a YouTube guy to do a video, but I'm not holding my breath waiting for these to make it to the local HVAC wholesaler anytime soon. Personally, I just want Mitsubishi to release air to water equipment to the US market at a reasonable price, and I can call it a day.
Can’t seem to wrap my brain around how an outdoor unit with a particular temperature range cascaded with another unit is going to work when you are no longer in the temperature range of the outdoor unit.
Its because each stage uses refrigerants with different boiling points. The first stage and second stage could be linked via an insulated heat exchanger such that outdoor ambient temp would not be a significant factor.
While cascade heat pumps are not new, these guys are claiming to be able to blend from mode(?) or some sorts to offer good low ambient (2 COP) while maintaining high ambient efficiency (4 COP).
I'm guessing they have a bypass mode for the lower temp loop.
I'm actually working on a cascade diy heat pump that pulls heat from the freezer and dumps to a pre hot water tank. I plan on R290 for the low temp and R600a for the high temp
Cascade heat pumps are good for getting a wider range of front / back temps. But good luck getting over 2.5 COP. Still better then electric heat.
I would love to see one of these units in a 1/2 ton mini split. Have a 48v DC option AND allow the user to program percentage of power instead of temp setting. Would be an off-gridders dream come true.
