CRenner
I know I bought the wrong inverter but I can't afford another, so I need to make this work.
Since I want to be totally off grid at times, this is what I hooked up:
My batteries feed the inverter which feeds the main panel through the AC Output, and that should start the Enphase.
When I turn this on, the inverter showed discharging the batteries at about 10-12 amps for the first 5 minutes.
Then the discharge went to zero but it never charged. Instead, the battery voltage climbed to 56 in about two minutes and the Enphase shut off and the discharge resumed.
I then connected a 12/3 cable from the main panel back to the AC Input on the inverter.
With this connected the AC Output was 60hz but the AC Input showed 52hz and the Enphase never started.
Why would the hertz change?
