JerryK
I purchased several of these for a few hobby projects & friends and family, now I have a few extras remaining, I purchased all of them in a lot purchase, they were used and are functioning 100%.
I believe I have five extras remaining and I plan on keeping a couple around.
They are for pick up only in the Twin Cities Minnesota, Northwest metro and I'm more than willing to connect them to power so you can see they function in fine.
I do not use digital currency services therefore it's a local pick up cash transaction you'll be picking up from our residence that we have owned since 1995.
These are very capable pure sine wave inverter's in the retail was someplace around $500 USD plus or minus.
At $100 each seems more than fair.
Included within the pictures there are some with the cover removed so you can see the quality build, very robust.
I also have them listed on the local craigslist as well as FB marketplace.
Features:
True sine wave output (THD < 3%)
Power ON-OFF remote control
Input & output fully isolation
Load control cooling fan
Advanced microprocessor
Output frequency 50/60 Hz switch selectable
Low power saving mode to conserve energy
Input polarity reverse / under voltage / over voltage protections
Output short circuit / overload / over temperature protections
Tri-color indicators display input, output level & failure statuse
-13 / CE / FCC approved.
Specifications:
Here are some info a links to copy & paste into a browser.
Inverters R Us:
User Manual:
Data Sheet:
Features:
Specifications:
- AC Voltage: 100 / 110 / 120VAC
- Continuous Power: 1500W
- Surge Power: 3000W
- Waveform: True sine wave (THD < 3%)
- Frequency: 50 / 60 Hz selectable by DIP switch
- AC Regulation: +/- 3%
- Standard Receptacles: x2 US North American GFCI
- LED Indicator: Input voltage level, output load level and fault status
- No Load Current Draw: .75A
- Stand By Current Draw: 0.15A
- DC Voltage: 24VDC
- Voltage Range: 21~30VDC
- Efficiency: 91%
- Fuse: 20A x 5
- Cooling: Loading controlled cooling fan
- Remote Control: CR6 / CR8 optional
- Battery Low Shutdown: 21VDC
- Over Load: Shut off output voltage, re-power on to recover
- Over Voltage: 30.6VDC
- Over Temp: Shut off output voltage, auto resets
- Output Short: Shut off output voltage, re-power on to recover
- Battery Polarity Reverse: By Fuse Open
- Safety Standards: Meet UL458
- Isolation Resistance: I/P ~ O/P: 100M Ohms / 500VDC
- EMI Conduction & Radiation: Compliance to FCC class A
- Dimensions(L x W x H): 16.3 x 7.5 x 3.5 in
- Weight: 10.5 lbs
Inverters R Us:
COTEK SK1500-124 1500 Watt 24V Pure Sine | Inverters R Us
The Cotek SK1500-124 Industrial Grade 1500 Watt 24 Volt Pure Sine Wave Inverter has free ground shipping everyday. Call us today!
invertersrus.com
Data Sheet:
