So, I have a mini system set up for now, one which I will hopefully be increasing as I go. I experienced some limitations when I was carrying out the purchase and, to cut the story short, I had to make do with what was available and supplied to me. So far, the unit works pretty well but an assumption was made when picking out the charge controller and a monitoring module was not provided with the one that was delivered. Also, the charge controller happens to be of a generic type, although the manual indicates it is an MPK series. The manufacturer hasn't been of any help, whom I was able to contact after days of running different types of searches. I was offered the option of procuring another unit but which will come with the Bluetooth module. That was not exactly helpful.
Forgive the overstretched backstory above.
The charge controller has a communication port labelled RS485, while the manual shows the communication mode to be "RS485, RJ45 port". I figured a RS485 compatible module should work but I wonder about the chances that I could be wrong. For example, EPEVER seems to be quite common on here and I have looked them up but I'm wondering if there is a chance that, although it is RS485, the alignment of the wires might be different from what would be compatible with my controller.
Is there anyone here with experience on EPEVER Bluetooth and WiFi modules that can advise on whether this will work with my device? I would really like to be able to monitor the controller remotely using the EPEVER app on mobile. Also, it might allow for a less tedious (with all those pressing of buttons on the controller) configuration or modification of settings.
Is there any universal type of module that should work? Is there any open source module and/or software that can be used as well?
Thank you in advance.
