Gomez38
- Jan 29, 2021
- 8
A couple years ago--while laid off during COVID--we got interested in setting up a solar system here at home. I bought some SOK batteries, a 3000w Growatt all-in-one, and some used cheap Santan panels. AFter initially playing around and doing some learning, I got another job and let it languish.
After receiving an offer on our old mobile home/land, we are going to move! In the short term, we bought a 5tth wheel with old, dying lead-acid golf cart batteries (6v, 2S-2P), and I would like to switch them with the 12v SOKs, but that brings up questions:
1) is it ok/safe to just drop the SOKs in as a replacement, 4P vs. 2S-2P so that we have proper 12v power?
2) I know the current charger will not give the LFPs a full charge, due to a lower charge voltage. Does this damage them? Or can we just run on reduced capacity until later upgrading the controller?
3) Can any charger handle multiple LFPs in parallel, i.e. it just takes 2x as long to charge 2, or 4x as long to charge 4, or is there a limit for a given charger? If so, what spec would I be looking for?
4) Any recommendations on a good LFP charger to do this job?
5) would the Growatt be ok for this job? It is a 24v system, so I know it would also require a 24v/12v converter to power the RV DC system.
thank you all.
thank you all.
